- a -
a :
PhaseCurrent_s
angle_register :
MagneticSensorI2CConfig_s
MagneticSensorSPIConfig_s
- b -
b :
PhaseCurrent_s
bit_resolution :
- c -
c :
PhaseCurrent_s
chip_address :
clock_speed :
MagneticSensorSPI
com_port :
Commander
command_parity_bit :
command_rw_bit :
controller :
FOCMotor
count :
StepDirListener
cpr :
HallSensor
current :
FOCMotor
current_limit :
FOCMotor
current_sense :
FOCMotor
current_sp :
FOCMotor
- d -
d :
DQCurrent_s
DQVoltage_s
D :
PIDController
data_start_bit :
dc_a :
BLDCDriver
dc_b :
BLDCDriver
dc_c :
BLDCDriver
dead_zone :
BLDCDriver6PWM
decimal_places :
Commander
dir1a :
StepperDriver2PWM
dir1b :
StepperDriver2PWM
dir2a :
StepperDriver2PWM
dir2b :
StepperDriver2PWM
direction :
HallSensor
driver :
BLDCMotor
StepperMotor
- e -
electric_rotations :
HallSensor
electric_sector :
HallSensor
electrical_angle :
FOCMotor
enable_pin :
BLDCDriver6PWM
enable_pin1 :
StepperDriver2PWM
StepperDriver4PWM
enable_pin2 :
StepperDriver2PWM
StepperDriver4PWM
enableA_pin :
BLDCDriver3PWM
enableB_pin :
BLDCDriver3PWM
enableC_pin :
BLDCDriver3PWM
enabled :
FOCMotor
error_prev :
PIDController
- f -
foc_modulation :
FOCMotor
- g -
gain_a :
InlineCurrentSense
gain_b :
InlineCurrentSense
gain_c :
InlineCurrentSense
- h -
hall_state :
HallSensor
- i -
I :
PIDController
index_pin :
integral_prev :
PIDController
- l -
limit :
PIDController
LPF_angle :
FOCMotor
LPF_current_d :
FOCMotor
LPF_current_q :
FOCMotor
LPF_velocity :
FOCMotor
- m -
modulation_centered :
FOCMotor
monitor_downsample :
FOCMotor
monitor_port :
FOCMotor
monitor_variables :
FOCMotor
motion_cnt :
FOCMotor
motion_downsample :
FOCMotor
- o -
output_prev :
PIDController
output_ramp :
PIDController
- p -
P :
PIDController
P_angle :
FOCMotor
phase_resistance :
FOCMotor
PID_current_d :
FOCMotor
PID_current_q :
FOCMotor
PID_velocity :
FOCMotor
pin :
wo_association
pin_dir :
StepDirListener
pin_step :
StepDirListener
pinA :
HallSensor
pinAnalog :
MagneticSensorAnalog
pinB :
HallSensor
pinC :
HallSensor
pole_pairs :
FOCMotor
port :
wo_association
pullup :
HallSensor
pwm1 :
StepperDriver2PWM
pwm1A :
StepperDriver4PWM
pwm1B :
StepperDriver4PWM
pwm2 :
StepperDriver2PWM
pwm2A :
StepperDriver4PWM
pwm2B :
StepperDriver4PWM
pwm_frequency :
BLDCDriver
StepperDriver
pwmA :
BLDCDriver3PWM
pwmA_h :
BLDCDriver6PWM
pwmA_l :
BLDCDriver6PWM
pwmB :
BLDCDriver3PWM
pwmB_h :
BLDCDriver6PWM
pwmB_l :
BLDCDriver6PWM
pwmC :
BLDCDriver3PWM
pwmC_h :
BLDCDriver6PWM
pwmC_l :
BLDCDriver6PWM
- q -
q :
DQCurrent_s
DQVoltage_s
quadrature :
- s -
sensor :
FOCMotor
sensor_direction :
FOCMotor
sensor_offset :
FOCMotor
shaft_angle :
FOCMotor
shaft_angle_sp :
FOCMotor
shaft_velocity :
FOCMotor
shaft_velocity_sp :
FOCMotor
skip_align :
CurrentSense
spi_mode :
MagneticSensorSPI
- t -
target :
FOCMotor
tccE :
wo_association
tccF :
wo_association
Tf :
LowPassFilter
timestamp_prev :
LowPassFilter
PIDController
torque_controller :
FOCMotor
total_interrupts :
HallSensor
- u -
Ua :
BLDCMotor
Ualpha :
BLDCMotor
StepperMotor
Ub :
BLDCMotor
Ubeta :
BLDCMotor
StepperMotor
Uc :
BLDCMotor
- v -
velocity_index_search :
FOCMotor
velocity_limit :
FOCMotor
verbose :
Commander
voltage :
FOCMotor
voltage_limit :
BLDCDriver
FOCMotor
StepperDriver
voltage_power_supply :
BLDCDriver
StepperDriver
voltage_sensor_align :
FOCMotor
- w -
woE :
wo_association
woF :
wo_association
- y -
y_prev :
LowPassFilter
- z -
zero_electric_angle :
FOCMotor
Generated by
1.8.18
