#include <BLDCDriver3PWM.h>
Public Member Functions | |
| BLDCDriver3PWM (int phA, int phB, int phC, int en1=NOT_SET, int en2=NOT_SET, int en3=NOT_SET) | |
| int | init () override |
| void | disable () override |
| void | enable () override |
| void | setPwm (float Ua, float Ub, float Uc) override |
| virtual void | setPhaseState (int sa, int sb, int sc) override |
Public Attributes | |
| int | pwmA |
| phase A pwm pin number More... | |
| int | pwmB |
| phase B pwm pin number More... | |
| int | pwmC |
| phase C pwm pin number More... | |
| int | enableA_pin |
| enable pin number More... | |
| int | enableB_pin |
| int | enableC_pin |
Public Attributes inherited from BLDCDriver | |
| long | pwm_frequency |
| pwm frequency value in hertz More... | |
| float | voltage_power_supply |
| power supply voltage More... | |
| float | voltage_limit |
| limiting voltage set to the motor More... | |
| float | dc_a |
| currently set duty cycle on phaseA More... | |
| float | dc_b |
| currently set duty cycle on phaseB More... | |
| float | dc_c |
| currently set duty cycle on phaseC More... | |
3 pwm bldc driver class
Definition at line 13 of file BLDCDriver3PWM.h.
| BLDCDriver3PWM::BLDCDriver3PWM | ( | int | phA, |
| int | phB, | ||
| int | phC, | ||
| int | en1 = NOT_SET, |
| int | en2 = NOT_SET, |
| int | en3 = NOT_SET |
BLDCDriver class constructor
| phA | A phase pwm pin |
| phB | B phase pwm pin |
| phC | C phase pwm pin |
| en1 | enable pin (optional input) |
| en2 | enable pin (optional input) |
| en3 | enable pin (optional input) |
Definition at line 3 of file BLDCDriver3PWM.cpp.
overridevirtual |
overridevirtual |
overridevirtual |
Motor hardware init function
Implements BLDCDriver.
Definition at line 43 of file BLDCDriver3PWM.cpp.
overridevirtual |
Set phase voltages to the harware
| sc | - phase A state : active / disabled ( high impedance ) |
| sb | - phase B state : active / disabled ( high impedance ) |
| sa | - phase C state : active / disabled ( high impedance ) |
Definition at line 68 of file BLDCDriver3PWM.cpp.
overridevirtual |
| Ua | - phase A voltage |
| Ub | - phase B voltage |
| Uc | - phase C voltage |
Definition at line 78 of file BLDCDriver3PWM.cpp.
| int BLDCDriver3PWM::enableA_pin |
enable pin number
Definition at line 38 of file BLDCDriver3PWM.h.
| int BLDCDriver3PWM::enableB_pin |
enable pin number
Definition at line 39 of file BLDCDriver3PWM.h.
| int BLDCDriver3PWM::enableC_pin |
enable pin number
Definition at line 40 of file BLDCDriver3PWM.h.
| int BLDCDriver3PWM::pwmA |
Definition at line 35 of file BLDCDriver3PWM.h.
| int BLDCDriver3PWM::pwmB |
Definition at line 36 of file BLDCDriver3PWM.h.
| int BLDCDriver3PWM::pwmC |
Definition at line 37 of file BLDCDriver3PWM.h.
