BLDCDriver3PWM.h
1
#ifndef BLDCDriver3PWM_h
#define BLDCDriver3PWM_h
3
#include "../common/base_classes/BLDCDriver.h"
5
#include "../common/foc_utils.h"
6
#include "../common/time_utils.h"
7
#include "../common/defaults.h"
8
#include "
hardware_api.h
9
13
class
BLDCDriver3PWM
public
BLDCDriver
14
15
public
25
BLDCDriver3PWM
int
phA,
int
phB,
int
phC,
int
en1 =
NOT_SET
int
en2 =
NOT_SET
int
en3 =
NOT_SET
26
28
int
init
override
30
void
disable
override
32
void
enable
override
33
34
// hardware variables
35
int
pwmA
36
int
pwmB
37
int
pwmC
38
int
enableA_pin
39
int
enableB_pin
40
int
enableC_pin
41
49
void
setPwm
float
Ua,
float
Ub,
float
Uc)
override
50
58
virtual
void
setPhaseState
int
sa,
int
sb,
int
sc)
override
59
private
60
61
62
63
64
#endif
BLDCDriver3PWM::pwmB
int pwmB
phase B pwm pin number
Definition:
BLDCDriver3PWM.h:36
BLDCDriver
Definition:
BLDCDriver.h:6
NOT_SET
#define NOT_SET
Definition:
foc_utils.h:27
BLDCDriver3PWM::init
int init() override
Definition:
BLDCDriver3PWM.cpp:43
BLDCDriver3PWM::pwmC
int pwmC
phase C pwm pin number
Definition:
BLDCDriver3PWM.h:37
BLDCDriver3PWM::disable
void disable() override
Definition:
BLDCDriver3PWM.cpp:31
BLDCDriver3PWM::pwmA
int pwmA
phase A pwm pin number
Definition:
BLDCDriver3PWM.h:35
BLDCDriver3PWM::BLDCDriver3PWM
BLDCDriver3PWM(int phA, int phB, int phC, int en1=NOT_SET, int en2=NOT_SET, int en3=NOT_SET)
Definition:
BLDCDriver3PWM::setPwm
void setPwm(float Ua, float Ub, float Uc) override
Definition:
BLDCDriver3PWM.cpp:78
hardware_api.h
BLDCDriver3PWM::enableB_pin
int enableB_pin
enable pin number
Definition:
BLDCDriver3PWM.h:39
void enable() override
Definition:
BLDCDriver3PWM.cpp:21
BLDCDriver3PWM::setPhaseState
virtual void setPhaseState(int sa, int sb, int sc) override
Definition:
BLDCDriver3PWM.cpp:68
BLDCDriver3PWM::enableA_pin
int enableA_pin
enable pin number
Definition:
BLDCDriver3PWM.h:38
BLDCDriver3PWM
Definition:
BLDCDriver3PWM.h:14
BLDCDriver3PWM::enableC_pin
int enableC_pin
enable pin number
Definition:
BLDCDriver3PWM.h:40
Arduino
libraries
Arduino-FOC
src
drivers
BLDCDriver3PWM.h
Generated by
1.8.18
