#include <BLDCDriver6PWM.h>
Public Member Functions | |
| BLDCDriver6PWM (int phA_h, int phA_l, int phB_h, int phB_l, int phC_h, int phC_l, int en=NOT_SET) | |
| int | init () override |
| void | disable () override |
| void | enable () override |
| void | setPwm (float Ua, float Ub, float Uc) override |
| virtual void | setPhaseState (int sa, int sb, int sc) override |
Public Attributes | |
| int | pwmA_h |
| int | pwmA_l |
| phase A pwm pin number More... | |
| int | pwmB_h |
| int | pwmB_l |
| phase B pwm pin number More... | |
| int | pwmC_h |
| int | pwmC_l |
| phase C pwm pin number More... | |
| int | enable_pin |
| enable pin number More... | |
| float | dead_zone |
| a percentage of dead-time(zone) (both high and low side in low) for each pwm cycle [0,1] More... | |
Public Attributes inherited from BLDCDriver | |
| long | pwm_frequency |
| pwm frequency value in hertz More... | |
| float | voltage_power_supply |
| power supply voltage More... | |
| float | voltage_limit |
| limiting voltage set to the motor More... | |
| float | dc_a |
| currently set duty cycle on phaseA More... | |
| float | dc_b |
| currently set duty cycle on phaseB More... | |
| float | dc_c |
| currently set duty cycle on phaseC More... | |
6 pwm bldc driver class
Definition at line 13 of file BLDCDriver6PWM.h.
| BLDCDriver6PWM::BLDCDriver6PWM | ( | int | phA_h, |
| int | phA_l, | ||
| int | phB_h, | ||
| int | phB_l, | ||
| int | phC_h, | ||
| int | phC_l, | ||
| int | en = NOT_SET |
BLDCDriver class constructor
| phA_h | A phase pwm pin |
| phA_l | A phase pwm pin |
| phB_h | B phase pwm pin |
| phB_l | A phase pwm pin |
| phC_h | C phase pwm pin |
| phC_l | A phase pwm pin |
| en | enable pin (optional input) |
Definition at line 3 of file BLDCDriver6PWM.cpp.
overridevirtual |
overridevirtual |
overridevirtual |
Motor hardware init function
Implements BLDCDriver.
Definition at line 43 of file BLDCDriver6PWM.cpp.
overridevirtual |
Set phase voltages to the harware
| sc | - phase A state : active / disabled ( high impedance ) |
| sb | - phase B state : active / disabled ( high impedance ) |
| sa | - phase C state : active / disabled ( high impedance ) |
Definition at line 83 of file BLDCDriver6PWM.cpp.
overridevirtual |
| Ua | - phase A voltage |
| Ub | - phase B voltage |
| Uc | - phase C voltage |
Definition at line 66 of file BLDCDriver6PWM.cpp.
| float BLDCDriver6PWM::dead_zone |
Definition at line 41 of file BLDCDriver6PWM.h.
| int BLDCDriver6PWM::enable_pin |
enable pin number
Definition at line 39 of file BLDCDriver6PWM.h.
| int BLDCDriver6PWM::pwmA_h |
Definition at line 36 of file BLDCDriver6PWM.h.
| int BLDCDriver6PWM::pwmA_l |
| int BLDCDriver6PWM::pwmB_h |
Definition at line 37 of file BLDCDriver6PWM.h.
| int BLDCDriver6PWM::pwmB_l |
| int BLDCDriver6PWM::pwmC_h |
Definition at line 38 of file BLDCDriver6PWM.h.
| int BLDCDriver6PWM::pwmC_l |
