#include <HallSensor.h>
Public Member Functions | |
| HallSensor (int encA, int encB, int encC, int pp) | |
| void | init () |
| void | enableInterrupts (void(*doA)()=nullptr, void(*doB)()=nullptr, void(*doC)()=nullptr) |
| void | handleA () |
| void | handleB () |
| void | handleC () |
| float | getAngle () override |
| float | getVelocity () override |
| void | attachSectorCallback (void(*onSectorChange)(int a)=nullptr) |
Public Member Functions inherited from Sensor | |
| virtual int | needsSearch () |
Public Attributes | |
| int | pinA |
| HallSensor hardware pin A. More... | |
| int | pinB |
| HallSensor hardware pin B. More... | |
| int | pinC |
| HallSensor hardware pin C. More... | |
| Pullup | pullup |
| Configuration parameter internal or external pullups. More... | |
| float | cpr |
| HallSensor cpr number. More... | |
| Direction | direction |
| volatile int8_t | hall_state |
| volatile int8_t | electric_sector |
| volatile long | electric_rotations |
| volatile long | total_interrupts |
Definition at line 12 of file HallSensor.h.
| HallSensor::HallSensor | ( | int | encA, |
| int | encB, | ||
| int | encC, | ||
| int | pp | ||
HallSensor class constructor
| encA | HallSensor A pin |
| encB | HallSensor B pin |
| encC | HallSensor C pin |
| pp | pole pairs (e.g hoverboard motor has 15pp and small gimbals often have 7pp) |
| index | index pin number (optional input) |
Definition at line 9 of file HallSensor.cpp.
| void HallSensor::attachSectorCallback | ( | void(*)(int a) | onSectorChange = nullptr | ) |
Optionally set a function callback to be fired when sector changes void onSectorChange(int sector) { ... // for debug or call driver directly? } sensor.attachSectorCallback(onSectorChange);
Definition at line 91 of file HallSensor.cpp.
| void HallSensor::enableInterrupts | ( | void(*)() | doA = nullptr, |
| void(*)() | doB = nullptr, |
| void(*)() | doC = nullptr |
function enabling hardware interrupts for the HallSensor channels with provided callback functions if callback is not provided then the interrupt is not enabled
| doA | pointer to the A channel interrupt handler function |
| doB | pointer to the B channel interrupt handler function |
| doIndex | pointer to the Index channel interrupt handler function |
Definition at line 144 of file HallSensor.cpp.
overridevirtual |
overridevirtual |
get current angular velocity (rad/s)
Reimplemented from Sensor.
Definition at line 106 of file HallSensor.cpp.
| void HallSensor::handleA | ( | ) |
A channel callback function
Definition at line 25 of file HallSensor.cpp.
| void HallSensor::handleB | ( | ) |
B channel callback function
Definition at line 30 of file HallSensor.cpp.
| void HallSensor::handleC | ( | ) |
C channel callback function
Definition at line 36 of file HallSensor.cpp.
| void HallSensor::init | ( | ) |
HallSensor initialise pins
Definition at line 117 of file HallSensor.cpp.
| float HallSensor::cpr |
Definition at line 53 of file HallSensor.h.
| Direction HallSensor::direction |
Definition at line 62 of file HallSensor.h.
| volatile long HallSensor::electric_rotations |
Definition at line 71 of file HallSensor.h.
| volatile int8_t HallSensor::electric_sector |
Definition at line 69 of file HallSensor.h.
| volatile int8_t HallSensor::hall_state |
Definition at line 67 of file HallSensor.h.
| int HallSensor::pinA |
Definition at line 47 of file HallSensor.h.
| int HallSensor::pinB |
Definition at line 48 of file HallSensor.h.
| int HallSensor::pinC |
Definition at line 49 of file HallSensor.h.
| Pullup HallSensor::pullup |
Definition at line 52 of file HallSensor.h.
| volatile long HallSensor::total_interrupts |
Definition at line 73 of file HallSensor.h.
