#include <StepDirListener.h>
Public Member Functions | |
| StepDirListener (int pinStep, int pinDir, float counter_to_value=1) | |
| void | enableInterrupt (void(*handleStep)()) |
| void | init () |
| void | handle () |
| float | getValue () |
| void | attach (float *variable) |
Public Attributes | |
| int | pin_step |
| step pin More... | |
| int | pin_dir |
| direction pin More... | |
| long | count |
| current counter value - should be set to 0 for homing More... | |
Step/Dir listenner class for easier interraction with this communication interface.
Definition at line 10 of file StepDirListener.h.
| StepDirListener::StepDirListener | ( | int | pinStep, |
| int | pinDir, | ||
| float | counter_to_value = 1 |
Constructor for step/direction interface
| step | - pin |
| direction | - pin |
| counter_to_value | - step counter to value |
Definition at line 3 of file StepDirListener.cpp.
| void StepDirListener::attach | ( | float * | variable | ) |
Attach the value to be updated on each step receive
Definition at line 19 of file StepDirListener.cpp.
| void StepDirListener::enableInterrupt | ( | void(*)() | handleStep | ) |
Start listenning for step commands
| handleStep | - on step received handler |
Definition at line 15 of file StepDirListener.cpp.
| float StepDirListener::getValue | ( | ) |
Get so far received valued
Definition at line 38 of file StepDirListener.cpp.
| void StepDirListener::handle | ( | ) |
step handler
Definition at line 23 of file StepDirListener.cpp.
| void StepDirListener::init | ( | ) |
Initialise dir and step commands
Definition at line 9 of file StepDirListener.cpp.
| long StepDirListener::count |
Definition at line 49 of file StepDirListener.h.
| int StepDirListener::pin_dir |
direction pin
Definition at line 48 of file StepDirListener.h.
| int StepDirListener::pin_step |
step pin
Definition at line 47 of file StepDirListener.h.
