| StepperDriver * | driver |
| float | Ualpha |
| float | Ubeta |
| | Phase voltages U alpha and U beta used for inverse Park and Clarke transform. More...
| float | target |
| | current target value - depends of the controller More...
| float | shaft_angle |
| | current motor angle More...
| float | electrical_angle |
| | current electrical angle More...
| float | shaft_velocity |
| | current motor velocity More...
| float | current_sp |
| | target current ( q current ) More...
| float | shaft_velocity_sp |
| | current target velocity More...
| float | shaft_angle_sp |
| | current target angle More...
| DQVoltage_s | voltage |
| | current d and q voltage set to the motor More...
| DQCurrent_s | current |
| | current d and q current measured More...
| float | voltage_sensor_align |
| | sensor and motor align voltage parameter More...
| float | velocity_index_search |
| | target velocity for index search More...
| float | phase_resistance |
| | motor phase resistance More...
| int | pole_pairs |
| | motor pole pairs number More...
| float | voltage_limit |
| | Voltage limitting variable - global limit. More...
| float | current_limit |
| | Current limitting variable - global limit. More...
| float | velocity_limit |
| | Velocity limitting variable - global limit. More...
| int8_t | enabled = 0 |
| | enabled or disabled motor flag More...
| FOCModulationType | foc_modulation |
| | parameter derterniming modulation algorithm More...
| int8_t | modulation_centered = 1 |
| | flag (1) centered modulation around driver limit /2 or (0) pulled to 0 More...
| TorqueControlType | torque_controller |
| | parameter determining the torque control type More...
| MotionControlType | controller |
| | parameter determining the control loop to be used More...
| PIDController | PID_current_q {DEF_PID_CURR_P,DEF_PID_CURR_I,DEF_PID_CURR_D,DEF_PID_CURR_RAMP, DEF_POWER_SUPPLY} |
| | parameter determining the q current PID config More...
| PIDController | PID_current_d {DEF_PID_CURR_P,DEF_PID_CURR_I,DEF_PID_CURR_D,DEF_PID_CURR_RAMP, DEF_POWER_SUPPLY} |
| | parameter determining the d current PID config More...
| LowPassFilter | LPF_current_q {DEF_CURR_FILTER_Tf} |
| | parameter determining the current Low pass filter configuration More...
| LowPassFilter | LPF_current_d {DEF_CURR_FILTER_Tf} |
| PIDController | PID_velocity {DEF_PID_VEL_P,DEF_PID_VEL_I,DEF_PID_VEL_D,DEF_PID_VEL_RAMP,DEF_PID_VEL_LIMIT} |
| | parameter determining the velocity PID configuration More...
| PIDController | P_angle {DEF_P_ANGLE_P,0,0,1e10,DEF_VEL_LIM} |
| | parameter determining the position PID configuration More...
| LowPassFilter | LPF_velocity {DEF_VEL_FILTER_Tf} |
| | parameter determining the velocity Low pass filter configuration More...
| LowPassFilter | LPF_angle {0.0} |
| | parameter determining the angle low pass filter configuration More...
| unsigned int | motion_downsample = DEF_MOTION_DOWNSMAPLE |
| | parameter defining the ratio of downsampling for move commad More...
| unsigned int | motion_cnt = 0 |
| | counting variable for downsampling for move commad More...
| float | sensor_offset |
| | user defined sensor zero offset More...
| float | zero_electric_angle = NOT_SET |
| | absolute zero electric angle - if available More...
| int | sensor_direction = NOT_SET |
| | if sensor_direction == Direction::CCW then direction will be flipped to CW More...
| unsigned int | monitor_downsample = DEF_MON_DOWNSMAPLE |
| | show monitor outputs each monitor_downsample calls More...
| uint8_t | monitor_variables = _MON_TARGET | _MON_VOLT_Q | _MON_VEL | _MON_ANGLE |
| | Bit array holding the map of variables the user wants to monitor. More...
| Sensor * | sensor |
| CurrentSense * | current_sense |
| Print * | monitor_port |
| | Serial terminal variable if provided. More...
Stepper Motor class
Definition at line 20 of file StepperMotor.h.
