StepperMotor.h
1
6
#ifndef StepperMotor_h
7
#define StepperMotor_h
8
9
#include "Arduino.h"
10
#include "
common/base_classes/FOCMotor.h
11
#include "
common/base_classes/StepperDriver.h
12
#include "
common/base_classes/Sensor.h
13
#include "
common/foc_utils.h
14
#include "
common/time_utils.h
15
#include "
common/defaults.h
16
20
class
StepperMotor
public
FOCMotor
21
22
public
28
StepperMotor
int
pp,
float
R =
NOT_SET
29
35
void
linkDriver
StepperDriver
driver
36
41
StepperDriver
driver
42
44
void
init
override
46
void
disable
override
48
void
enable
override
49
60
int
initFOC
float
zero_electric_offset =
NOT_SET
Direction
sensor_direction
Direction::CW
override
67
void
loopFOC
override
76
void
move
float
target
NOT_SET
override
77
78
float
Ualpha
Ubeta
79
80
private
81
82
// FOC methods
91
void
setPhaseVoltage(
float
Uq,
float
Ud ,
float
angle_el);
92
94
int
alignSensor();
96
int
absoluteZeroSearch();
97
98
// Open loop motion control
105
float
velocityOpenloop(
float
target_velocity);
112
float
angleOpenloop(
float
target_angle);
113
// open loop variables
114
long
open_loop_timestamp;
115
116
117
118
#endif
FOCMotor.h
StepperMotor::StepperMotor
StepperMotor(int pp, float R=NOT_SET)
Definition:
StepperMotor.cpp:6
StepperMotor::initFOC
int initFOC(float zero_electric_offset=NOT_SET, Direction sensor_direction=Direction::CW) override
Definition:
StepperMotor.cpp:85
CW
@ CW
Definition:
Sensor.h:8
FOCMotor
Definition:
FOCMotor.h:58
NOT_SET
#define NOT_SET
Definition:
foc_utils.h:27
StepperDriver
Definition:
StepperDriver.h:4
defaults.h
StepperMotor::init
void init() override
Definition:
StepperMotor.cpp:27
Sensor.h
foc_utils.h
StepperMotor::Ubeta
float Ubeta
Phase voltages U alpha and U beta used for inverse Park and Clarke transform.
Definition:
StepperMotor.h:78
StepperMotor::linkDriver
void linkDriver(StepperDriver *driver)
Definition:
StepperMotor.cpp:22
StepperMotor::loopFOC
void loopFOC() override
Definition:
StepperMotor.cpp:215
FOCMotor::target
float target
current target value - depends of the controller
Definition:
FOCMotor.h:131
FOCMotor::sensor_direction
int sensor_direction
if sensor_direction == Direction::CCW then direction will be flipped to CW
Definition:
FOCMotor.h:181
StepperMotor::disable
void disable() override
Definition:
StepperMotor.cpp:60
StepperDriver.h
StepperMotor::Ualpha
float Ualpha
Definition:
StepperMotor.h:78
StepperMotor
Definition:
StepperMotor.h:21
StepperMotor::move
void move(float target=NOT_SET) override
Definition:
StepperMotor.cpp:234
StepperMotor::driver
StepperDriver * driver
Definition:
StepperMotor.h:41
time_utils.h
Direction
Direction
Definition:
Sensor.h:7
StepperMotor::enable
void enable() override
Definition:
StepperMotor.cpp:70
Arduino
libraries
Arduino-FOC
src
StepperMotor.h
Generated by
1.8.18
