Go to the source code of this file.
Macros | |
| #define | DEF_POWER_SUPPLY 12.0 |
| default power supply voltage More... | |
| #define | DEF_PID_VEL_P 0.5 |
| default PID controller P value More... | |
| #define | DEF_PID_VEL_I 10.0 |
| default PID controller I value More... | |
| #define | DEF_PID_VEL_D 0.0 |
| default PID controller D value More... | |
| #define | DEF_PID_VEL_RAMP 1000.0 |
| default PID controller voltage ramp value More... | |
| #define | DEF_PID_VEL_LIMIT (DEF_POWER_SUPPLY) |
| default PID controller voltage limit More... | |
| #define | DEF_PID_CURR_P 3 |
| #define | DEF_PID_CURR_I 300.0 |
| #define | DEF_PID_CURR_D 0.0 |
| #define | DEF_PID_CURR_RAMP 1e11 |
| #define | DEF_PID_CURR_LIMIT (DEF_POWER_SUPPLY) |
| #define | DEF_CURR_FILTER_Tf 0.005 |
| default currnet filter time constant More... | |
| #define | DEF_CURRENT_LIM 0.2 |
| 2Amps current limit by default More... | |
| #define | DEF_MON_DOWNSMAPLE 100 |
| default monitor downsample More... | |
| #define | DEF_MOTION_DOWNSMAPLE 0 |
| default motion downsample - disable More... | |
| #define | DEF_P_ANGLE_P 20.0 |
| default P controller P value More... | |
| #define | DEF_VEL_LIM 20.0 |
| angle velocity limit default More... | |
| #define | DEF_INDEX_SEARCH_TARGET_VELOCITY 1.0 |
| default index search velocity More... | |
| #define | DEF_VOLTAGE_SENSOR_ALIGN 3.0 |
| default voltage for sensor and motor zero alignemt More... | |
| #define DEF_CURR_FILTER_Tf 0.005 |
Definition at line 29 of file defaults.h.
| #define DEF_CURRENT_LIM 0.2 |
Definition at line 32 of file defaults.h.
| #define DEF_INDEX_SEARCH_TARGET_VELOCITY 1.0 |
Definition at line 43 of file defaults.h.
| #define DEF_MON_DOWNSMAPLE 100 |
Definition at line 35 of file defaults.h.
| #define DEF_MOTION_DOWNSMAPLE 0 |
Definition at line 36 of file defaults.h.
| #define DEF_P_ANGLE_P 20.0 |
Definition at line 39 of file defaults.h.
| #define DEF_PID_CURR_D 0.0 |
Definition at line 26 of file defaults.h.
| #define DEF_PID_CURR_I 300.0 |
Definition at line 25 of file defaults.h.
| #define DEF_PID_CURR_LIMIT (DEF_POWER_SUPPLY) |
Definition at line 28 of file defaults.h.
| #define DEF_PID_CURR_P 3 |
Definition at line 24 of file defaults.h.
| #define DEF_PID_CURR_RAMP 1e11 |
Definition at line 27 of file defaults.h.
| #define DEF_PID_VEL_D 0.0 |
Definition at line 9 of file defaults.h.
| #define DEF_PID_VEL_I 10.0 |
Definition at line 8 of file defaults.h.
| #define DEF_PID_VEL_LIMIT (DEF_POWER_SUPPLY) |
Definition at line 11 of file defaults.h.
| #define DEF_PID_VEL_P 0.5 |
Definition at line 7 of file defaults.h.
| #define DEF_PID_VEL_RAMP 1000.0 |
Definition at line 10 of file defaults.h.
| #define DEF_POWER_SUPPLY 12.0 |
Definition at line 5 of file defaults.h.
| #define DEF_VEL_LIM 20.0 |
Definition at line 40 of file defaults.h.
| #define DEF_VOLTAGE_SENSOR_ALIGN 3.0 |
Definition at line 45 of file defaults.h.
