HybridStepperMotor Class Reference
#include <HybridStepperMotor.h>
Inheritance diagram for HybridStepperMotor:
[legend]
Collaboration diagram for HybridStepperMotor:
[legend]
Public Member Functions
 HybridStepperMotor (int pp, float R=NOT_SET, float KV=NOT_SET, float L_q=NOT_SET, float L_d=NOT_SET)
void linkDriver (BLDCDriver *driver)
int init () override
void disable () override
void enable () override
void setPhaseVoltage (float Uq, float Ud, float angle_el) override
float estimateBEMF (float velocity) override
int characteriseMotor (float voltage)
void linkCurrentSense (CurrentSense *current_sense)
- Public Member Functions inherited from FOCMotor
 FOCMotor ()
virtual int initFOC ()
virtual void loopFOC ()
virtual void move (float target=NOT_SET)
void linkSensor (Sensor *sensor)
float shaftAngle ()
float shaftVelocity ()
float electricalAngle ()
int characteriseMotor (float voltage, float correction_factor)
int tuneCurrentController (float bandwidth)
void useMonitoring (Print &serial)
void monitor ()
void updateVelocityLimit (float new_velocity_limit)
void updateCurrentLimit (float new_current_limit)
void updateVoltageLimit (float new_voltage_limit)
void updateTorqueControlType (TorqueControlType new_torque_controller)
void updateMotionControlType (MotionControlType new_motion_controller)
float velocityOpenloop (float target_velocity)
float angleOpenloop (float target_angle)
void linkCustomMotionControl (float(*controlMethod)(FOCMotor *motor))
Public Attributes
BLDCDriverdriver
 BLDCDriver instance.
float Ua
float Ub
float Uc
 Phase voltages used for inverse Park and Clarke transform.
- Public Attributes inherited from FOCMotor
float target
 current target value - depends of the controller
float feed_forward_velocity = 0.0f
 current feed forward velocity
float shaft_angle
 current motor angle
float electrical_angle
 current electrical angle
float shaft_velocity
 current motor velocity
float current_sp
 target current ( q current )
float shaft_velocity_sp
 current target velocity
float shaft_angle_sp
 current target angle
DQVoltage_s voltage
 current d and q voltage set to the motor
DQCurrent_s current
 current d and q current measured
float voltage_bemf
 estimated backemf voltage (if provided KV constant)
float Ualpha
float Ubeta
 Phase voltages U alpha and U beta used for inverse Park and Clarke transform.
DQCurrent_s feed_forward_current
DQVoltage_s feed_forward_voltage
float voltage_sensor_align
 sensor and motor align voltage parameter
float velocity_index_search
 target velocity for index search
float phase_resistance
 motor phase resistance
int pole_pairs
 motor pole pairs number
float KV_rating
 motor KV rating
float phase_inductance
 motor phase inductance q axis - FOR BACKWARDS COMPATIBILITY
DQ_s axis_inductance {NOT_SET, NOT_SET}
 motor direct axis phase inductance
float voltage_limit
 Voltage limiting variable - global limit.
float current_limit
 Current limiting variable - global limit.
float velocity_limit
 Velocity limiting variable - global limit.
int8_t enabled = 0
 enabled or disabled motor flag
FOCMotorStatus motor_status = FOCMotorStatus::motor_uninitialized
 motor status
FOCModulationType foc_modulation
 parameter determining modulation algorithm
int8_t modulation_centered = 1
 flag (1) centered modulation around driver limit /2 or (0) pulled to 0
TorqueControlType torque_controller
 parameter determining the torque control type
MotionControlType controller
 parameter determining the control loop to be used
PIDController PID_current_q {DEF_PID_CURR_P,DEF_PID_CURR_I,DEF_PID_CURR_D,DEF_PID_CURR_RAMP, DEF_POWER_SUPPLY}
 parameter determining the q current PID config
PIDController PID_current_d {DEF_PID_CURR_P,DEF_PID_CURR_I,DEF_PID_CURR_D,DEF_PID_CURR_RAMP, DEF_POWER_SUPPLY}
 parameter determining the d current PID config
LowPassFilter LPF_current_q {DEF_CURR_FILTER_Tf}
 parameter determining the current Low pass filter configuration
LowPassFilter LPF_current_d {DEF_CURR_FILTER_Tf}
PIDController PID_velocity {DEF_PID_VEL_P,DEF_PID_VEL_I,DEF_PID_VEL_D,DEF_PID_VEL_RAMP,DEF_PID_VEL_LIMIT}
 parameter determining the velocity PID configuration
PIDController P_angle {DEF_P_ANGLE_P,0,0,0,DEF_VEL_LIM}
 parameter determining the position PID configuration
LowPassFilter LPF_velocity {DEF_VEL_FILTER_Tf}
 parameter determining the velocity Low pass filter configuration
LowPassFilter LPF_angle {0.0}
 parameter determining the angle low pass filter configuration
unsigned int motion_downsample = DEF_MOTION_DOWNSMAPLE
 parameter defining the ratio of downsampling for move commad
unsigned int motion_cnt = 0
 counting variable for downsampling for move commad
float sensor_offset
 user defined sensor zero offset
float zero_electric_angle = NOT_SET
 absolute zero electric angle - if available
Direction sensor_direction = Direction::UNKNOWN
 default is CW. if sensor_direction == Direction::CCW then direction will be flipped compared to CW. Set to UNKNOWN to set by calibration
bool pp_check_result = false
 the result of the PP check, if run during loopFOC
unsigned int monitor_downsample = DEF_MON_DOWNSMAPLE
 show monitor outputs each monitor_downsample calls
char monitor_start_char = '\0'
 monitor starting character
char monitor_end_char = '\0'
 monitor outputs ending character
char monitor_separator = '\t'
 monitor outputs separation character
unsigned int monitor_decimals = 4
 monitor outputs decimal places
uint8_t monitor_variables = _MON_TARGET | _MON_VOLT_Q | _MON_VEL | _MON_ANGLE
 Bit array holding the map of variables the user wants to monitor.
Sensorsensor
 CurrentSense link.
CurrentSensecurrent_sense
Print * monitor_port
 Serial terminal variable if provided.
uint32_t loopfoc_time_us = 0
 filtered loop times
uint32_t move_time_us = 0
Additional Inherited Members
- Protected Member Functions inherited from FOCMotor
void updateLoopFOCTime ()
void updateMotionControlTime ()
int alignSensor ()
int alignCurrentSense ()
int absoluteZeroSearch ()
- Protected Attributes inherited from FOCMotor
uint32_t last_loopfoc_timestamp_us = 0
 timestamp of the last loopFOC execution in microseconds
uint32_t last_loopfoc_time_us = 0
 last elapsed time of loopFOC in microseconds
uint32_t last_move_timestamp_us = 0
 timestamp of the last move execution in microseconds
uint32_t last_move_time_us = 0
 last elapsed time of move in microseconds
Detailed Description
Stepper Motor class
Definition at line 20 of file HybridStepperMotor.h.
Constructor & Destructor Documentation
◆ HybridStepperMotor()
HybridStepperMotor::HybridStepperMotor ( int  pp,
float  R = NOT_SET,
float  KV = NOT_SET,
float  L_q = NOT_SET,
float  L_d = NOT_SET
HybridStepperMotor class constructor
Parameters
pppole pair number
Rmotor phase resistance - [Ohm]
KVmotor KV rating (1/K_bemf) - rpm/V
Lqmotor q-axis inductance - [H]
Ldmotor d-axis inductance - [H]
Definition at line 10 of file HybridStepperMotor.cpp.
Member Function Documentation
◆ characteriseMotor()
int HybridStepperMotor::characteriseMotor ( float  voltage)
inline
Measure resistance and inductance of a HybridStepperMotor and print results to debug. If a sensor is available, an estimate of zero electric angle will be reported too. TODO: determine the correction factor
Parameters
voltageThe voltage applied to the motor
Returns
0 for success, >0 for failure
Definition at line 81 of file HybridStepperMotor.h.
Here is the call graph for this function:
◆ disable()
void HybridStepperMotor::disable ( )
overridevirtual
Motor disable function
Implements FOCMotor.
Definition at line 95 of file HybridStepperMotor.cpp.
◆ enable()
void HybridStepperMotor::enable ( )
overridevirtual
Motor enable function
Definition at line 108 of file HybridStepperMotor.cpp.
Here is the caller graph for this function:
◆ estimateBEMF()
float HybridStepperMotor::estimateBEMF ( float  velocity)
overridevirtual
Method estimating the Back EMF voltage based based on the current velocity and KV rating
Parameters
velocityCurrent motor velocity
Reimplemented from FOCMotor.
Definition at line 126 of file HybridStepperMotor.cpp.
◆ init()
int HybridStepperMotor::init ( )
overridevirtual
Motor hardware init function
Definition at line 47 of file HybridStepperMotor.cpp.
◆ linkCurrentSense()
void HybridStepperMotor::linkCurrentSense ( CurrentSense current_sense)
Link the currentsense
Definition at line 41 of file HybridStepperMotor.cpp.
◆ linkDriver()
void HybridStepperMotor::linkDriver ( BLDCDriver _driver)
Function linking a motor and a foc driver
Parameters
driverBLDCDriver handle for hardware peripheral control
Link the driver which controls the motor
Definition at line 33 of file HybridStepperMotor.cpp.
◆ setPhaseVoltage()
void HybridStepperMotor::setPhaseVoltage ( float  Uq,
float  Ud,
float  angle_el
overridevirtual
Method using FOC to set Uq to the motor at the optimal angle Heart of the FOC algorithm
Parameters
UqCurrent voltage in q axis to set to the motor
UdCurrent voltage in d axis to set to the motor
angle_elcurrent electrical angle of the motor
Definition at line 135 of file HybridStepperMotor.cpp.
Member Data Documentation
◆ driver
BLDCDriver* HybridStepperMotor::driver
Definition at line 40 of file HybridStepperMotor.h.
◆ Ua
float HybridStepperMotor::Ua
Definition at line 42 of file HybridStepperMotor.h.
◆ Ub
float HybridStepperMotor::Ub
◆ Uc
float HybridStepperMotor::Uc
The documentation for this class was generated from the following files:
