FOCDriver Class Referenceabstract
#include <FOCDriver.h>
Inheritance diagram for FOCDriver:
[legend]
Public Member Functions
virtual int init ()=0
virtual void enable ()=0
virtual void disable ()=0
virtual DriverType type ()=0
Public Attributes
long pwm_frequency
 pwm frequency value in hertz
float voltage_power_supply
 power supply voltage
float voltage_limit
bool initialized = false
 true if driver was successfully initialized
void * params = 0
 pointer to hardware specific parameters of driver
bool enable_active_high = true
 enable pin should be set to high to enable the driver (default is HIGH)
Detailed Description
FOC driver class
Definition at line 25 of file FOCDriver.h.
Member Function Documentation
◆ disable()
virtual void FOCDriver::disable ( )
pure virtual
Disable hardware
Implemented in BLDCDriver3PWM, BLDCDriver6PWM, StepperDriver2PWM, and StepperDriver4PWM.
Here is the caller graph for this function:
◆ enable()
virtual void FOCDriver::enable ( )
pure virtual
Enable hardware
◆ init()
virtual int FOCDriver::init ( )
pure virtual
Initialise hardware
◆ type()
virtual DriverType FOCDriver::type ( )
pure virtual
get the driver type
Implemented in BLDCDriver, and StepperDriver.
Member Data Documentation
◆ enable_active_high
bool FOCDriver::enable_active_high = true
Definition at line 42 of file FOCDriver.h.
◆ initialized
bool FOCDriver::initialized = false
Definition at line 39 of file FOCDriver.h.
◆ params
void* FOCDriver::params = 0
Definition at line 40 of file FOCDriver.h.
◆ pwm_frequency
long FOCDriver::pwm_frequency
Definition at line 35 of file FOCDriver.h.
◆ voltage_limit
float FOCDriver::voltage_limit
Definition at line 37 of file FOCDriver.h.
◆ voltage_power_supply
float FOCDriver::voltage_power_supply
Definition at line 36 of file FOCDriver.h.
The documentation for this class was generated from the following file:
