LowsideCurrentSense Class Reference
#include <LowsideCurrentSense.h>
Inheritance diagram for LowsideCurrentSense:
[legend]
Collaboration diagram for LowsideCurrentSense:
[legend]
Public Member Functions
 LowsideCurrentSense (float shunt_resistor, float gain, int pinA, int pinB, int pinC=_NC)
 LowsideCurrentSense (float mVpA, int pinA, int pinB, int pinC=_NC)
int init () override
PhaseCurrent_s getPhaseCurrents () override
- Public Member Functions inherited from CurrentSense
void linkDriver (FOCDriver *driver)
virtual int driverAlign (float align_voltage, bool modulation_centered=false)
virtual float getDCCurrent (float angle_el=0)
DQCurrent_s getFOCCurrents (float angle_el)
ABCurrent_s getABCurrents (PhaseCurrent_s current)
DQCurrent_s getDQCurrents (ABCurrent_s current, float angle_el)
virtual void enable ()
virtual void disable ()
int alignBLDCDriver (float align_voltage, BLDCDriver *driver, bool modulation_centered)
int alignStepperDriver (float align_voltage, StepperDriver *driver, bool modulation_centered)
int alignHybridDriver (float align_voltage, BLDCDriver *driver, bool modulation_centered)
PhaseCurrent_s readAverageCurrents (int N=100)
Additional Inherited Members
- Public Attributes inherited from CurrentSense
bool skip_align = false
 variable signaling that the phase current direction should be verified during initFOC()
FOCDriverdriver = nullptr
 driver link
bool initialized = false
void * params = 0
 pointer to hardware specific parameters of current sensing
DriverType driver_type = DriverType::UnknownDriver
 driver type (BLDC or Stepper)
float gain_a
 phase A gain
float gain_b
 phase B gain
float gain_c
 phase C gain
float offset_ia
 zero current A voltage value (center of the adc reading)
float offset_ib
 zero current B voltage value (center of the adc reading)
float offset_ic
 zero current C voltage value (center of the adc reading)
int pinA
 pin A analog pin for current measurement
int pinB
 pin B analog pin for current measurement
int pinC
 pin C analog pin for current measurement
Detailed Description
Definition at line 16 of file LowsideCurrentSense.h.
Constructor & Destructor Documentation
◆ LowsideCurrentSense() [1/2]
LowsideCurrentSense::LowsideCurrentSense ( float  shunt_resistor,
float  gain,
int  pinA,
int  pinB,
int  pinC = _NC
LowsideCurrentSense class constructor
Parameters
shunt_resistorshunt resistor value
gaincurrent-sense op-amp gain
phAA phase adc pin
phBB phase adc pin
phCC phase adc pin (optional)
Definition at line 9 of file LowsideCurrentSense.cpp.
◆ LowsideCurrentSense() [2/2]
LowsideCurrentSense::LowsideCurrentSense ( float  mVpA,
int  pinA,
int  pinB,
int  pinC = _NC
Parameters
mVpAmV per Amp ratio
phAA phase adc pin
phBB phase adc pin
Definition at line 24 of file LowsideCurrentSense.cpp.
Member Function Documentation
◆ getPhaseCurrents()
PhaseCurrent_s LowsideCurrentSense::getPhaseCurrents ( )
overridevirtual
Function rading the phase currents a, b and c This function will be used with the foc control throught the function CurrentSense::getFOCCurrents(electrical_angle)
  • it returns current c equal to 0 if only two phase measurements available
Returns
PhaseCurrent_s current values
Implements CurrentSense.
Definition at line 88 of file LowsideCurrentSense.cpp.
Here is the call graph for this function:
◆ init()
int LowsideCurrentSense::init ( )
overridevirtual
Function intialising the CurrentSense class
  • All the necessary intialisations of adc and sync should be implemented here
Returns
- 0 - for failure & 1 - for success
Definition at line 38 of file LowsideCurrentSense.cpp.
The documentation for this class was generated from the following files:
