Go to the source code of this file.
Macros | |
| #define | CMD_C_D_PID 'D' |
| current d PID & LPF More... | |
| #define | CMD_C_Q_PID 'Q' |
| #define | CMD_V_PID 'V' |
| velocity PID & LPF More... | |
| #define | CMD_A_PID 'A' |
| angle PID & LPF More... | |
| #define | CMD_STATUS 'E' |
| motor status enable/disable More... | |
| #define | CMD_LIMITS 'L' |
| limits current/voltage/velocity More... | |
| #define | CMD_MOTION_TYPE 'C' |
| motion control type More... | |
| #define | CMD_TORQUE_TYPE 'T' |
| torque control type More... | |
| #define | CMD_SENSOR 'S' |
| sensor offsets More... | |
| #define | CMD_MONITOR 'M' |
| monitoring More... | |
| #define | CMD_RESIST 'R' |
| motor phase resistance More... | |
| #define | CMD_SCAN '?' |
| command scaning the network - only for commander More... | |
| #define | CMD_VERBOSE '@' |
| command setting output mode - only for commander More... | |
| #define | CMD_DECIMAL '#' |
| command setting decimal places - only for commander More... | |
| #define | SCMD_PID_P 'P' |
| PID gain P. More... | |
| #define | SCMD_PID_I 'I' |
| PID gain I. More... | |
| #define | SCMD_PID_D 'D' |
| PID gain D. More... | |
| #define | SCMD_PID_RAMP 'R' |
| PID ramp. More... | |
| #define | SCMD_PID_LIM 'L' |
| PID limit. More... | |
| #define | SCMD_LPF_TF 'F' |
| LPF time constant. More... | |
| #define | SCMD_LIM_CURR 'C' |
| Limit current. More... | |
| #define | SCMD_LIM_VOLT 'U' |
| Limit voltage. More... | |
| #define | SCMD_LIM_VEL 'V' |
| Limit velocity. More... | |
| #define | SCMD_SENS_MECH_OFFSET 'M' |
| Sensor offset. More... | |
| #define | SCMD_SENS_ELEC_OFFSET 'E' |
| Sensor electrical zero offset. More... | |
| #define | SCMD_DOWNSAMPLE 'D' |
| Monitoring downsample value. More... | |
| #define | SCMD_CLEAR 'C' |
| Clear all monitored variables. More... | |
| #define | SCMD_GET 'G' |
| Get variable only one value. More... | |
| #define | SCMD_SET 'S' |
| Set variables to be monitored. More... | |
| #define CMD_A_PID 'A' |
angle PID & LPF
Definition at line 11 of file commands.h.
| #define CMD_C_D_PID 'D' |
current d PID & LPF
Definition at line 8 of file commands.h.
| #define CMD_C_Q_PID 'Q' |
current d PID & LPF
Definition at line 9 of file commands.h.
| #define CMD_DECIMAL '#' |
Definition at line 23 of file commands.h.
| #define CMD_LIMITS 'L' |
Definition at line 13 of file commands.h.
| #define CMD_MONITOR 'M' |
monitoring
Definition at line 17 of file commands.h.
| #define CMD_MOTION_TYPE 'C' |
motion control type
Definition at line 14 of file commands.h.
| #define CMD_RESIST 'R' |
Definition at line 18 of file commands.h.
| #define CMD_SCAN '?' |
Definition at line 21 of file commands.h.
| #define CMD_SENSOR 'S' |
sensor offsets
Definition at line 16 of file commands.h.
| #define CMD_STATUS 'E' |
Definition at line 12 of file commands.h.
| #define CMD_TORQUE_TYPE 'T' |
torque control type
Definition at line 15 of file commands.h.
| #define CMD_V_PID 'V' |
velocity PID & LPF
Definition at line 10 of file commands.h.
| #define CMD_VERBOSE '@' |
Definition at line 22 of file commands.h.
| #define SCMD_CLEAR 'C' |
Definition at line 42 of file commands.h.
| #define SCMD_DOWNSAMPLE 'D' |
Definition at line 41 of file commands.h.
| #define SCMD_GET 'G' |
Definition at line 43 of file commands.h.
| #define SCMD_LIM_CURR 'C' |
Limit current.
Definition at line 34 of file commands.h.
| #define SCMD_LIM_VEL 'V' |
Limit velocity.
Definition at line 36 of file commands.h.
| #define SCMD_LIM_VOLT 'U' |
Limit voltage.
Definition at line 35 of file commands.h.
| #define SCMD_LPF_TF 'F' |
LPF time constant.
Definition at line 32 of file commands.h.
| #define SCMD_PID_D 'D' |
PID gain D.
Definition at line 29 of file commands.h.
| #define SCMD_PID_I 'I' |
PID gain I.
Definition at line 28 of file commands.h.
| #define SCMD_PID_LIM 'L' |
PID limit.
Definition at line 31 of file commands.h.
| #define SCMD_PID_P 'P' |
PID gain P.
Definition at line 27 of file commands.h.
| #define SCMD_PID_RAMP 'R' |
PID ramp.
Definition at line 30 of file commands.h.
| #define SCMD_SENS_ELEC_OFFSET 'E' |
Definition at line 39 of file commands.h.
| #define SCMD_SENS_MECH_OFFSET 'M' |
Sensor offset.
Definition at line 38 of file commands.h.
| #define SCMD_SET 'S' |
Definition at line 44 of file commands.h.
