#include "foc_utils.h"Go to the source code of this file.
Functions | |
| float | _sin (float a) |
| float | _cos (float a) |
| float | _normalizeAngle (float angle) |
| float | _electricalAngle (float shaft_angle, int pole_pairs) |
| float | _sqrtApprox (float number) |
Variables | |
| const int | sine_array [200] = {0,79,158,237,316,395,473,552,631,710,789,867,946,1024,1103,1181,1260,1338,1416,1494,1572,1650,1728,1806,1883,1961,2038,2115,2192,2269,2346,2423,2499,2575,2652,2728,2804,2879,2955,3030,3105,3180,3255,3329,3404,3478,3552,3625,3699,3772,3845,3918,3990,4063,4135,4206,4278,4349,4420,4491,4561,4631,4701,4770,4840,4909,4977,5046,5113,5181,5249,5316,5382,5449,5515,5580,5646,5711,5775,5839,5903,5967,6030,6093,6155,6217,6279,6340,6401,6461,6521,6581,6640,6699,6758,6815,6873,6930,6987,7043,7099,7154,7209,7264,7318,7371,7424,7477,7529,7581,7632,7683,7733,7783,7832,7881,7930,7977,8025,8072,8118,8164,8209,8254,8298,8342,8385,8428,8470,8512,8553,8594,8634,8673,8712,8751,8789,8826,8863,8899,8935,8970,9005,9039,9072,9105,9138,9169,9201,9231,9261,9291,9320,9348,9376,9403,9429,9455,9481,9506,9530,9554,9577,9599,9621,9642,9663,9683,9702,9721,9739,9757,9774,9790,9806,9821,9836,9850,9863,9876,9888,9899,9910,9920,9930,9939,9947,9955,9962,9969,9975,9980,9985,9989,9992,9995,9997,9999,10000,10000} |
| float _cos | ( | float | a | ) |
Function approximating cosine calculation by using fixed size array
| a | angle in between 0 and 2PI |
Definition at line 39 of file foc_utils.cpp.
| float _electricalAngle | ( | float | shaft_angle, |
| int | pole_pairs | ||
Electrical angle calculation
| shaft_angle | - shaft angle of the motor |
| pole_pairs | - number of pole pairs |
Definition at line 53 of file foc_utils.cpp.
| float _normalizeAngle | ( | float | angle | ) |
normalizing radian angle to [0,2PI]
| angle | - angle to be normalized |
Definition at line 47 of file foc_utils.cpp.
| float _sin | ( | float | a | ) |
Function approximating the sine calculation by using fixed size array
Definition at line 14 of file foc_utils.cpp.
| float _sqrtApprox | ( | float | value | ) |
Function approximating square root function
| value | - number |
Definition at line 60 of file foc_utils.cpp.
| const int sine_array[200] = {0,79,158,237,316,395,473,552,631,710,789,867,946,1024,1103,1181,1260,1338,1416,1494,1572,1650,1728,1806,1883,1961,2038,2115,2192,2269,2346,2423,2499,2575,2652,2728,2804,2879,2955,3030,3105,3180,3255,3329,3404,3478,3552,3625,3699,3772,3845,3918,3990,4063,4135,4206,4278,4349,4420,4491,4561,4631,4701,4770,4840,4909,4977,5046,5113,5181,5249,5316,5382,5449,5515,5580,5646,5711,5775,5839,5903,5967,6030,6093,6155,6217,6279,6340,6401,6461,6521,6581,6640,6699,6758,6815,6873,6930,6987,7043,7099,7154,7209,7264,7318,7371,7424,7477,7529,7581,7632,7683,7733,7783,7832,7881,7930,7977,8025,8072,8118,8164,8209,8254,8298,8342,8385,8428,8470,8512,8553,8594,8634,8673,8712,8751,8789,8826,8863,8899,8935,8970,9005,9039,9072,9105,9138,9169,9201,9231,9261,9291,9320,9348,9376,9403,9429,9455,9481,9506,9530,9554,9577,9599,9621,9642,9663,9683,9702,9721,9739,9757,9774,9790,9806,9821,9836,9850,9863,9876,9888,9899,9910,9920,9930,9939,9947,9955,9962,9969,9975,9980,9985,9989,9992,9995,9997,9999,10000,10000} |
Definition at line 7 of file foc_utils.cpp.
