SimpleFOClibrary 2.4.0
#include <MagneticSensorPWM.h>
Public Member Functions | |
| MagneticSensorPWM (uint8_t _pinPWM, int _min=0, int _max=0) | |
| MagneticSensorPWM (uint8_t _pinPWM, int freqHz, int _total_pwm_clocks, int _min_pwm_clocks, int _max_pwm_clocks) | |
| void | init () |
| void | update () override |
| float | getSensorAngle () override |
| void | handlePWM () |
| void | enableInterrupt (void(*doPWM)()) |
Public Member Functions inherited from Sensor | |
| virtual float | getMechanicalAngle () |
| virtual float | getAngle () |
| virtual double | getPreciseAngle () |
| virtual float | getVelocity () |
| virtual int32_t | getFullRotations () |
| virtual int | needsSearch () |
Public Attributes | |
| int | pinPWM |
| unsigned long | pulse_length_us |
| unsigned int | timeout_us = 1200 |
Public Attributes inherited from Sensor | |
| float | min_elapsed_time = 0.000100 |
Additional Inherited Members | |
Protected Attributes inherited from Sensor | |
| float | velocity =0.0f |
| float | angle_prev =0.0f |
| long | angle_prev_ts =0 |
| float | vel_angle_prev =0.0f |
| long | vel_angle_prev_ts =0 |
| int32_t | full_rotations =0 |
| int32_t | vel_full_rotations =0 |
Definition at line 11 of file MagneticSensorPWM.h.
| MagneticSensorPWM::MagneticSensorPWM | ( | uint8_t | _pinPWM, |
| int | _min_raw_count = 0, |
| int | _max_raw_count = 0 |
MagneticSensorPWM(uint8_t _pinPWM, int _min, int _max)
| _pinPWM | the pin that is reading the pwm from magnetic sensor |
| _min_raw_count | the smallest expected reading |
| _max_raw_count | the largest expected reading |
Definition at line 9 of file MagneticSensorPWM.cpp.
| int | freqHz, | ||
| int | _total_pwm_clocks, | ||
| int | _min_pwm_clocks, | ||
| int | _max_pwm_clocks | ||
Constructor that computes the min and max raw counts based on the PWM frequency and the number of PWM clocks in one period
| freqHz | the frequency of the PWM signal, in Hz, e.g. 115, 230, 460 or 920 for the AS5600, depending on the PWM frequency setting |
| _total_pwm_clocks | the total number of PWM clocks in one period, e.g. 4351 for the AS5600 |
| _min_pwm_clocks | the 0 value returned by the sensor, in PWM clocks, e.g. 128 for the AS5600 |
| _max_pwm_clocks | the largest value returned by the sensor, in PWM clocks, e.g. 4223 for the AS5600 |
Definition at line 35 of file MagneticSensorPWM.cpp.
| void MagneticSensorPWM::enableInterrupt | ( | void(*)() | doPWM | ) |
Definition at line 111 of file MagneticSensorPWM.cpp.
overridevirtual |
Get current shaft angle from the sensor hardware, and return it as a float in radians, in the range 0 to 2PI.
This method is pure virtual and must be implemented in subclasses. Calling this method directly does not update the base-class internal fields. Use update() when calling from outside code.
Implements Sensor.
Definition at line 75 of file MagneticSensorPWM.cpp.
| void MagneticSensorPWM::handlePWM | ( | ) |
virtual |
Call Sensor::init() from your sensor subclass's init method if you want smoother startup The base class init() method calls getSensorAngle() several times to initialize the internal fields to current values, ensuring there is no discontinuity ("jump from zero") during the first calls to sensor.getAngle() and sensor.getVelocity()
Reimplemented from Sensor.
Definition at line 54 of file MagneticSensorPWM.cpp.
overridevirtual |
Updates the sensor values by reading the hardware sensor. Some implementations may work with interrupts, and not need this. The base implementation calls getSensorAngle(), and updates internal fields for angle, timestamp and full rotations. This method must be called frequently enough to guarantee that full rotations are not "missed" due to infrequent polling. Override in subclasses if alternative behaviours are required for your sensor hardware.
Definition at line 65 of file MagneticSensorPWM.cpp.
| int MagneticSensorPWM::pinPWM |
Definition at line 34 of file MagneticSensorPWM.h.
| unsigned long MagneticSensorPWM::pulse_length_us |
Definition at line 45 of file MagneticSensorPWM.h.
| unsigned int MagneticSensorPWM::timeout_us = 1200 |
Definition at line 47 of file MagneticSensorPWM.h.
