MagneticSensorI2C Class Reference
#include <MagneticSensorI2C.h>
Inheritance diagram for MagneticSensorI2C:
[legend]
Collaboration diagram for MagneticSensorI2C:
[legend]
Public Member Functions
 MagneticSensorI2C (uint8_t _chip_address, int _bit_resolution, uint8_t _angle_register_msb, int _msb_bits_used, bool lsb_right_aligned=true)
 MagneticSensorI2C (MagneticSensorI2CConfig_s config)
void init (TwoWire *_wire=&Wire)
float getSensorAngle () override
int checkBus (byte sda_pin, byte scl_pin)
- Public Member Functions inherited from Sensor
virtual float getMechanicalAngle ()
virtual float getAngle ()
virtual double getPreciseAngle ()
virtual float getVelocity ()
virtual int32_t getFullRotations ()
virtual void update ()
virtual int needsSearch ()
Static Public Member Functions
static MagneticSensorI2C AS5600 ()
Public Attributes
uint8_t currWireError = 0
- Public Attributes inherited from Sensor
float min_elapsed_time = 0.000100
Additional Inherited Members
- Protected Member Functions inherited from Sensor
virtual void init ()
- Protected Attributes inherited from Sensor
float velocity =0.0f
float angle_prev =0.0f
long angle_prev_ts =0
float vel_angle_prev =0.0f
long vel_angle_prev_ts =0
int32_t full_rotations =0
int32_t vel_full_rotations =0
Detailed Description
Definition at line 29 of file MagneticSensorI2C.h.
Constructor & Destructor Documentation
◆ MagneticSensorI2C() [1/2]
MagneticSensorI2C::MagneticSensorI2C ( uint8_t  _chip_address,
int  _msb_bits_used,
bool  lsb_right_aligned = true
MagneticSensorI2C class constructor
Parameters
chip_addressI2C chip address
bitsnumber of bits of the sensor resolution
angle_register_msbangle read register msb
_bits_used_msbnumber of used bits in msb
Definition at line 42 of file MagneticSensorI2C.cpp.
◆ MagneticSensorI2C() [2/2]
MagneticSensorI2C::MagneticSensorI2C ( MagneticSensorI2CConfig_s  config)
Parameters
configI2C config
Definition at line 63 of file MagneticSensorI2C.cpp.
Member Function Documentation
◆ AS5600()
MagneticSensorI2C MagneticSensorI2C::AS5600 ( )
static
Definition at line 71 of file MagneticSensorI2C.cpp.
◆ checkBus()
int MagneticSensorI2C::checkBus ( byte  sda_pin,
byte  scl_pin
experimental function to check and fix SDA locked LOW issues
Definition at line 123 of file MagneticSensorI2C.cpp.
Here is the call graph for this function:
◆ getSensorAngle()
float MagneticSensorI2C::getSensorAngle ( )
overridevirtual
get current angle (rad)
Implements Sensor.
Definition at line 87 of file MagneticSensorI2C.cpp.
◆ init()
void MagneticSensorI2C::init ( TwoWire *  _wire = &Wire)
sensor initialise pins
Definition at line 77 of file MagneticSensorI2C.cpp.
Member Data Documentation
◆ currWireError
uint8_t MagneticSensorI2C::currWireError = 0
current error code from Wire endTransmission() call
Definition at line 59 of file MagneticSensorI2C.h.
The documentation for this class was generated from the following files:
