5#if defined(ESP_H) && defined(ARDUINO_ARCH_ESP32)
6#define SIMPLEFOC_ADC_ATTEN ADC_11db
7#define SIMPLEFOC_ADC_RES 12
9static portMUX_TYPE spinlock = portMUX_INITIALIZER_UNLOCKED;
11#if CONFIG_IDF_TARGET_ESP32
13#include "soc/sens_reg.h"
21void IRAM_ATTR __configFastADCs(){
23 SIMPLEFOC_ESP32_CS_DEBUG(
"Configuring fast ADCs");
26 SET_PERI_REG_MASK(SENS_SAR_READ_CTRL_REG, SENS_SAR1_DATA_INV);
27 SET_PERI_REG_MASK(SENS_SAR_READ_CTRL2_REG, SENS_SAR2_DATA_INV);
29 SET_PERI_REG_MASK(SENS_SAR_MEAS_START1_REG, SENS_MEAS1_START_FORCE_M);
30 SET_PERI_REG_MASK(SENS_SAR_MEAS_START1_REG, SENS_SAR1_EN_PAD_FORCE_M);
31 SET_PERI_REG_MASK(SENS_SAR_MEAS_START2_REG, SENS_MEAS2_START_FORCE_M);
32 SET_PERI_REG_MASK(SENS_SAR_MEAS_START2_REG, SENS_SAR2_EN_PAD_FORCE_M);
34 CLEAR_PERI_REG_MASK(SENS_SAR_MEAS_WAIT2_REG, SENS_FORCE_XPD_SAR_M);
35 SET_PERI_REG_BITS(SENS_SAR_MEAS_WAIT2_REG, SENS_FORCE_XPD_AMP, 0x2, SENS_FORCE_XPD_AMP_S);
37 CLEAR_PERI_REG_MASK(SENS_SAR_MEAS_CTRL_REG, 0xfff << SENS_AMP_RST_FB_FSM_S);
38 SET_PERI_REG_BITS(SENS_SAR_MEAS_WAIT1_REG, SENS_SAR_AMP_WAIT1, 0x1, SENS_SAR_AMP_WAIT1_S);
39 SET_PERI_REG_BITS(SENS_SAR_MEAS_WAIT1_REG, SENS_SAR_AMP_WAIT2, 0x1, SENS_SAR_AMP_WAIT2_S);
40 SET_PERI_REG_BITS(SENS_SAR_MEAS_WAIT2_REG, SENS_SAR_AMP_WAIT3, 0x1, SENS_SAR_AMP_WAIT3_S);
41 while (GET_PERI_REG_BITS2(SENS_SAR_SLAVE_ADDR1_REG, 0x7, SENS_MEAS_STATUS_S) != 0);
46uint16_t IRAM_ATTR adcRead(uint8_t pin)
48 int8_t channel = digitalPinToAnalogChannel(pin);
50 SIMPLEFOC_ESP32_CS_DEBUG(
"ERROR: Not ADC pin: "+String(pin));
56 uint8_t adc_num = (channel >= SOC_ADC_MAX_CHANNEL_NUM) ? 2 : 1;
57 uint8_t adc_channel = (adc_num == 2) ? (channel - SOC_ADC_MAX_CHANNEL_NUM) : channel;
63 portENTER_CRITICAL(&spinlock);
69 CLEAR_PERI_REG_MASK(SENS_SAR_MEAS_START1_REG, SENS_MEAS1_START_SAR_M);
70 SET_PERI_REG_BITS(SENS_SAR_MEAS_START1_REG, SENS_SAR1_EN_PAD, (1 << channel), SENS_SAR1_EN_PAD_S);
71 SET_PERI_REG_MASK(SENS_SAR_MEAS_START1_REG, SENS_MEAS1_START_SAR_M);
74 while (GET_PERI_REG_MASK(SENS_SAR_MEAS_START1_REG, SENS_MEAS1_DONE_SAR) == 0);
76 value = GET_PERI_REG_BITS2(SENS_SAR_MEAS_START1_REG, SENS_MEAS1_DATA_SAR, SENS_MEAS1_DATA_SAR_S);
80 CLEAR_PERI_REG_MASK(SENS_SAR_MEAS_START2_REG, SENS_MEAS2_START_SAR_M);
81 SET_PERI_REG_BITS(SENS_SAR_MEAS_START2_REG, SENS_SAR2_EN_PAD, (1 << (adc_channel)), SENS_SAR2_EN_PAD_S);
82 SET_PERI_REG_MASK(SENS_SAR_MEAS_START2_REG, SENS_MEAS2_START_SAR_M);
85 while (GET_PERI_REG_MASK(SENS_SAR_MEAS_START2_REG, SENS_MEAS2_DONE_SAR) == 0);
87 value = GET_PERI_REG_BITS2(SENS_SAR_MEAS_START2_REG, SENS_MEAS2_DATA_SAR, SENS_MEAS2_DATA_SAR_S);
91 portEXIT_CRITICAL(&spinlock);
97#elif CONFIG_IDF_TARGET_ESP32S2 || CONFIG_IDF_TARGET_ESP32S3
99#include "soc/sens_reg.h"
124uint16_t IRAM_ATTR adcRead(uint8_t pin)
126 int8_t channel = digitalPinToAnalogChannel(pin);
128 SIMPLEFOC_ESP32_CS_DEBUG(
134 uint8_t adc_num = (channel >= SOC_ADC_MAX_CHANNEL_NUM) ? 2 : 1;
135 uint8_t adc_channel = (adc_num == 2) ? (channel - SOC_ADC_MAX_CHANNEL_NUM) : channel;
141 portENTER_CRITICAL(&spinlock);
147 CLEAR_PERI_REG_MASK(SENS_SAR_MEAS1_CTRL2_REG, SENS_MEAS1_START_SAR_M);
148 SET_PERI_REG_BITS(SENS_SAR_MEAS1_CTRL2_REG, SENS_SAR1_EN_PAD, (1 << (adc_channel)), SENS_SAR1_EN_PAD_S);
149 SET_PERI_REG_MASK(SENS_SAR_MEAS1_CTRL2_REG, SENS_MEAS1_START_SAR_M);
152 while (GET_PERI_REG_MASK(SENS_SAR_MEAS1_CTRL2_REG, SENS_MEAS1_DONE_SAR) == 0);
154 value = GET_PERI_REG_BITS2(SENS_SAR_MEAS1_CTRL2_REG, SENS_MEAS1_DATA_SAR, SENS_MEAS1_DATA_SAR_S);
158 CLEAR_PERI_REG_MASK(SENS_SAR_MEAS2_CTRL2_REG, SENS_MEAS2_START_SAR_M);
159 SET_PERI_REG_BITS(SENS_SAR_MEAS2_CTRL2_REG, SENS_SAR2_EN_PAD, (1 << (adc_channel)), SENS_SAR2_EN_PAD_S);
160 SET_PERI_REG_MASK(SENS_SAR_MEAS2_CTRL2_REG, SENS_MEAS2_START_SAR_M);
163 while (GET_PERI_REG_MASK(SENS_SAR_MEAS2_CTRL2_REG, SENS_MEAS2_DONE_SAR) == 0);
165 value = GET_PERI_REG_BITS2(SENS_SAR_MEAS2_CTRL2_REG, SENS_MEAS2_DATA_SAR, SENS_MEAS2_DATA_SAR_S);
169 portEXIT_CRITICAL(&spinlock);
176#pragma message("SimpleFOC: Using analogRead for ADC reading, no fast ADC configuration available!")
178uint16_t IRAM_ATTR adcRead(uint8_t pin){
179 return analogRead(pin);
186bool IRAM_ATTR adcInit(uint8_t pin){
187 static bool initialized =
false;
189 int8_t channel = digitalPinToAnalogChannel(pin);
191 SIMPLEFOC_ESP32_CS_DEBUG(
195 uint8_t adc_num = (channel >= SOC_ADC_MAX_CHANNEL_NUM) ? 2 : 1;
196 uint8_t adc_channel = (adc_num == 2) ? (channel - SOC_ADC_MAX_CHANNEL_NUM) : channel;
198 SIMPLEFOC_ESP32_CS_DEBUG(
"Configuring ADC"+String(adc_num)+
" channel "+String(adc_channel));
201 analogSetAttenuation(SIMPLEFOC_ADC_ATTEN);
202 analogReadResolution(SIMPLEFOC_ADC_RES);
204 pinMode(pin, ANALOG);
206 analogSetPinAttenuation(pin, SIMPLEFOC_ADC_ATTEN);
208#if CONFIG_IDF_TARGET_ESP32
