BLDCMotor Member List
This is the complete list of members for
BLDCMotor
, including all inherited members.
BLDCMotor
(int pp, float R=NOT_SET)
BLDCMotor
controller
FOCMotor
current
FOCMotor
current_limit
FOCMotor
current_sense
FOCMotor
current_sp
FOCMotor
disable
() override
BLDCMotor
virtual
driver
BLDCMotor
electrical_angle
FOCMotor
electricalAngle
FOCMotor
enable
() override
BLDCMotor
virtual
enabled
FOCMotor
foc_modulation
FOCMotor
FOCMotor
FOCMotor
init
() override
BLDCMotor
virtual
initFOC
(float zero_electric_offset=NOT_SET, Direction sensor_direction=Direction::CW) override
BLDCMotor
virtual
linkCurrentSense
(CurrentSense *current_sense)
FOCMotor
linkDriver
(BLDCDriver *driver)
BLDCMotor
linkSensor
(Sensor *sensor)
FOCMotor
loopFOC
() override
BLDCMotor
virtual
LPF_angle
FOCMotor
LPF_current_d
FOCMotor
LPF_current_q
FOCMotor
LPF_velocity
FOCMotor
modulation_centered
FOCMotor
monitor
FOCMotor
monitor_downsample
FOCMotor
monitor_port
FOCMotor
monitor_variables
FOCMotor
motion_cnt
FOCMotor
motion_downsample
FOCMotor
move
(float target=NOT_SET) override
BLDCMotor
virtual
P_angle
FOCMotor
phase_resistance
FOCMotor
PID_current_d
FOCMotor
PID_current_q
FOCMotor
PID_velocity
FOCMotor
pole_pairs
FOCMotor
sensor
FOCMotor
sensor_direction
FOCMotor
sensor_offset
FOCMotor
shaft_angle
FOCMotor
shaft_angle_sp
FOCMotor
shaft_velocity
FOCMotor
shaft_velocity_sp
FOCMotor
shaftAngle
FOCMotor
shaftVelocity
FOCMotor
target
FOCMotor
torque_controller
FOCMotor
Ua
BLDCMotor
Ualpha
BLDCMotor
Ub
BLDCMotor
Ubeta
BLDCMotor
Uc
BLDCMotor
useMonitoring
(Print &serial)
FOCMotor
velocity_index_search
FOCMotor
velocity_limit
FOCMotor
voltage
FOCMotor
voltage_limit
FOCMotor
voltage_sensor_align
FOCMotor
zero_electric_angle
FOCMotor
Generated by
1.8.18
